Salta al contenuto principale
Guide di riparazione, supporto e informazioni sulla risoluzione dei problemi per i modelli MacBook Air con schermo da 13"
3664 Domande Visualizza tutte
Why is my screen like this and how can I fix it?
I have no idea how this happened but I opened my Mac and suddenly my screen had coloured stripes. plzz help, I use this computer for school!?
Questa è una buona domanda?
Punteggio 0
1 Commento
Can you tell us your exact model? Review this listing EveryMac - MacBook Air systems
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
The switching transistors imbedded within the LCD screen are failing (https://en.wikipedia.org/wiki/IPS_panel|IPS panel)]. Basically, the lines which control the column are leaking current as the color lines fade. You also have a roll-over condition where the bottom part of the image is placed at the top that’s the stuff between the displays edge and the menu bar.
I’m suspecting you have two issues here: The system may have had a liquid spill at some point which has damaged the LVDS cable and its connector on the logic board. You also have a damaged screen which was caused by a bang or something heavy was placed on it.
As we don’t know which model you have I can’t offer information on the needed parts.
Punteggio 1
Unfortunately not, this screen is physically broken inside. You would need to replace the whole screen.
Punteggio 0
Aggiungi la tua risposta
sigga sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 41
