Salta al contenuto principale
Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
I tried to change the screen but it wont turn on
i tried to change my screen but when i finished it wouldn’t turn on but i can still hear the charger plug in
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It sounds like the iPad is on but you just can’t see anything. Hopefully its just the screen but if it did this with the old screen, it might be a backlight issue. That is a lab repair that requires micro-soldering.
Punteggio 2
2 Commenti:
Also if the battery was never disconnected I recommend reseating the battery connector as sometimes that will work.
Note that when unplugging or plugging in the screen make sure battery is disconnected as that can cause the backlight filter to blow if it is still plugged in.
da
Someone told me i shocked my ipad
da
Aggiungi la tua risposta
Yousur Bajali sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 139
