Salta al contenuto principale
Tefal Actifry - Convection Cooker. First launched in 2006, this revolutionary, versatile fryer allows you to cook a wide range of meals economically and its also safer and easier to clean than other fryers
10 Domande Visualizza tutte
Actifry tefal error 6
I get error 6 after few minutes.
Questa è una buona domanda?
Punteggio 4
2 Commenti
how to repair E5,E6 on fryer tefal
da
Check the HZ may be defrance then specific of machine 50 or 60
da
Aggiungi un commento
6 Risposte
Soluzione Prescelta
There are two capacitors. Change both of them.
Punteggio 0
4 Commenti:
Can u put pictures please
da
There are a couple pictures here :
https://www.commentreparer.com/54293/Fri...
da
Where are they..? And what are they?
da
@Adrian Martin Take a look at the link in the second comment here by Eric B; there's a video and picture and places to buy the parts. It's in French, but that's what Google Translate is for.
da
Risposta Più Utile
The problem was on the electric circuit .
I have replaced the capacitors and the problem has been resolved!!!!
Punteggio 1
4 Commenti:
Please can you advise how to change the capacitors as ours started throwing the err6 fault code today but after 6 or 7 times of it doing it every minute or so it stopped and worked fine again so i imagine its on its last legs or overheating maybe
da
Could you advise where you got the capacitors and how much they cost please
Thanks regards Martyn
da
I also have the same error code. Please can you tell me where to buy the capacitors from. Jan
da
Not much help is it! Which capacitors. Sounds like a guess to me
da
I read somewhere that it may be caused by some fuse behind the display (soldered on) and/or faulty motor.
I am planning to disassemble my unit tonight. Maybe just the grease accumulated somewhere so I will try some cleanup first.
Punteggio 0
1 Commento:
well, I did disassemble the unit but I did not find anything that would cause an issue. Although I am not sure if it was like this before, but it seems to me that the top cover gets pretty hot and then I get the error.
da
The voltage of your domestic
network is too high; for safety
reasons your appliance should
be protected against the risks of overheating.
Punteggio 0
4 Commenti:
well, this not the case for my unit, as I did test it on different networks and different sockets. In my case, it does run for 3:20 initially then err6. After clearing error, it would run for up to 20-30 seconds and get err6 again and after clearing again up to 20-3- seconds. I will try to check the capacitors as Dimitris Louvaris suggested.
da
standard Tefal rubbish answer. I have checked my supply. Its down to a fault in the control panel. It over heats and misreads the voltage.
da
Ive tested my tefal actifry in 3 diferent household error 6 in all of them.
da
You must change NTC temperature probe sensor which is placed behind the element.
da
I have replaced both the motor and thermostat and that did not help. I did not have the tool to check circut board but visually all looked fine. At least now after 10 times of disaassembky I know how to do it. I will check the capacitors again.
The official info about contacting electric supply company is absolutely out of the question. I have tried different networks and sockets.
Punteggio 0
4 Commenti:
So how it went? @rogerino
da
@Carlos Garcia quick question. do you have the error 6 on the actifry? Error 6 appears to be related to overheating of the 330nF capacitors on the circuit board. If you have this error post a couple of pictures of your circuit board so we can check things out.
da
Do you mean rhe gray capacitors
da
I have model IH7000 and it gave the same error... now it is OK
da
i have similar issue
E6 code after 1-2 min ? Tefal Actifry
Punteggio 0
2 Commenti:
Follow!!! Please help
da
I am not an electrician or an engineer. If this is a fault in the design, then surely Tefal should be recalling the machines and repairing them for us?
da
Aggiungi la tua risposta
Dimitris Louvaris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 128
Ultimi 30 Giorni: 512
Tutti i Tempi: 17,840
