Salta al contenuto principale
Modello A1419 / EMC 3070 / Metà 2017 / processori Core i5 3.4, 3.5 o 3.8 GHz o Core i7 Kaby Lake 4.2 GHz (id ImAC18,3) / Retina 5k display. Fai riferimento alle guide del modello più vecchio dell'iMac 27" Retina 5K display (fine 2014 & 2015), dato che il sistema è molto simile.
Can iMac 5k 2017 upgrade to i9 processor?
I would like to upgrade the CPU of my mid 2017 imac 5k retina (3.8 GHz Intel Core i5 with Radeon Pro 580 8192 MB) to the i9 9900k or 9900kf cpu. Is this possible? I believe that the pinout for both these chips is the same, but I’m not sure if the chipset will accept the new cpu and whether my current motherboard will be able to utilize the full power of i9 and the OS will be able to handle it.
Questa è una buona domanda?
Punteggio 9
5 Commenti
I have a 2017 iMac and I run it with 2666 MHZ Ram (Well it shows as 2667 MHZ…) Works totally fine.
I have a 2018 Mac mini and removed it’s 2666 8 GB for an upgrade and put them in the iMac. and bought 32 GB separately , running the iMac with 40 GB of RAM totally fine.
I’m also exited if an i9 swap would work…
da
@schalex - Sorry no it won't
da
Hi people, does anyone else have another attitude on this topic? Do you believe that i5 5700K is not replaceable with either i7 8700K or i9 9900K for the 5K iMac 2017?
If not, what is the problem and why?
To extend what you agree/disagree
da
^^it has to do with bios settings, you can only swap cpu's with the same generation unless you wanna brick your mac
da
Then can the iMac take a 7900? Because I have one as well and I would like to enjoy more than just 4 cores
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
Sorry just not possible!
This series is limited to what Apple released iMac18,3. In this case the best you could install would be a 4.2 GHz Core i7 (I7-7700K).
These just won't work!
While all of them use the same socket (FCLGA1151) these use a modified socket.
The RAM speeds are also different DDR4-2133 Vs DDR4-2666 the logic board is not able to support it. And lastly the TDP this system requires is 91 W Vs the hotter 95 W CPU’s. And lastly, systems firmware won’t recognize the CPU.
Punteggio 5
3 Commenti:
L'unico processore i9 che può montare limac 27 2017 18.3 è il potentissimo i9-9900B 65watt, (socket 1151) 150% più performante del7700k
da
Il 9900k e il 9900kf non sono compatibili perché hanno il socket diverso FCLGA1151-2 ( anche se fisicamente uguali i piedini sono posizionati diversamente). Quindi l'unico processore potente con le stesse prestazioni del 9900k è la CPU i9-9900B che utilizza il socket 1151 (è difficile da trovare)
da
Scusa Paolo, il modello i9 9900B il modello indicato di seguito si tratta dello stesso di cui parli?
Intel® Core™ i9 i9-9900 3,1 GHz 16 MB Smart Cache LGA 1151 (Z H4) process: 8 14 nm 64 bits 65 W
Grazie in anticipo
Roger
da
Luke Miani performed this upgrade on You Tube and was successful. i9900 not k chips must be LGA 1151 and have a TDP of 65 watts. K designated chips have a TDP of 95 watts. I am preparing to do this cpu swap on my 2017 iMac also on the fence Highest end i7 or i9.
Punteggio 4
4 Commenti:
Did you do it?
da
Si logras que te funciones y todo vaya en marcha me alegrarías un monto, jeje ya que es lo que quiero hacer, subirle al máximo en este caso al i9 9900k si puede ser pero claro no entiendo mucho del tema.
Estaré al pendiente de tu respuesta. Muchas gracias ;) saludos JL.:)
If you manage to get you to work and everything going, you would make me happy a lot, hehe since that's what I want to do, raise it to the maximum in this case to the i9 9900k if it can be but of course I don't understand much about the subject.
I will be on the lookout for your answer. Thank you very much ;) greetings JL.:)
da
@yusitosk8 - Luke did a 2019 system not a 2017 big difference in the EFI code. You are limited to Kaby Lake CPUs
da
Hi.
No, there is no way to apply this processor.
The 2017 iMac only accepts Intel i7 7700K...
da
Hi!
Your iMac will not break, it will just not work.
Your 2017 iMac can only work with i7 7700K, a 2019 iMac can work with i9 9900K.
I have both versions and i have try both processors at the 2017 iMac.
In your cace I would sell your iMac, and buy another one (2019 i5 at low price) and upgrade it to i9.
This is what I have now in my 2019 iMac:
i9 9900K, 128GB RAM, 2TB NVMe & 4TB SATA SSD's.
Punteggio 1
If you have the equipment and tools to flash the ME region with new CPU power sequence, give it a try. There is nothing to lose.
Punteggio -2
3 Commenti:
How about writing something up on how to do that. I would be very interested on knowing how you would attempt to reprogram the EFI.
da
@danj Its posted on YouTube. https://youtu.be/aytG-V1SOZk
Simple drag and drop method to rebuild the corrupt ME region. To rewrite the firmware with device ID and component ID need some time to study. I did not work for 6 months just to figure out how the timing work, what is the code to write and finding the data is the worse nightmare. I am trying to upgrade the 2017 MBP storage but cannot find the chips on the market except I buy the expensive SSD drive with over $400 to pull the chips. It cost almost double the price because of the supply problem. I need the 48 Layers MLC NAND flash with 168 Pin 3Gb Samsung K9UUGY8 which is 500GB capacity each. No data sheet for the NAND flash from any manufacturer as they are keeping it confidential but supply only to the big ones.
The 2018 & 2019 500GB chips are available in the market but no 1TB unless order massive quantity with direct contract.
I will appreciate if anyone with experience on NAND can provide information but not lucky until this moment.
da
This doesn't really help as you need the resources from the given system and if the system was not sold with the given CPU you would need to create the needed resource or salvage a system with the needed EFI to then copy off. You also need a programer and access to the needed chips and lastly a Windows system for the reprograming tools you need. And you still need to remove and then replace the EFI chip with a good soldering iron or hot air station.
This is way harder than what this vid implies. And given most people here are only doing their own system would be more costly than its worth. This would be a very big reach for them.
da
Aggiungi la tua risposta
guttikar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 214
Tutti i Tempi: 16,135
