Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
1185 Domande Visualizza tutte
Option key seems to be stucked should I change trackpad only?
Hello, guys. I’m so nervous…
  1. 2 years ago, 2017, I spilled ice coffee on the keyboard of my macbook pro retina 2015 early 13’. and then I cleaned and replaced keyboard and battery. it was solved.
  2. 2018, summer, suddenly my keyboard didn’t work well. “Option key” seemed to be stucked, so I couldn’t input “English or Korean”. After all, I changed “keyboard and trackpad cable” only and then I could use keyboard well.
  3. However, recently, “option key” seemed to be stucked again!! even if I changed keyboard again!!!. I tried to use external keyboard, but it didn’t work well.
I guess my trackpad or mother board has a problem. While I used laptop, sometimes my trackpad didn’t work zoom in or out.
did you guys have same experience or have a solution? plz?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Your description makes me think some liquid might have reached the trackpad where it started some oxidation that built up over time. I’d definitely try a trackpad replacement as a first step before worrying about the logic board.
Punteggio 3
8 Commenti:
So, you mean the trackpad has something to do with the keyboard issue, especially "option key pressed"?
da
@samsational Absolutely, signals from they keyboard head to the trackpad where you have ICs elaborating them and forwarding them over on to the logic board.
da
Thank you so much, @arbaman
If the laptop does not work well after replacing the trackpad, what should I do?
Should I consider replacing a logic board or motherboard?
da
@samsational Considering market prices next step I'd consider would be a component level repair rather than a replacement, but let's keep fingers crossed for now.
da
@arbaman yes, you're right. But I have a one more question. My trackpad did work well except for zoom in or out. Is it related this keyboard issue?
da
Mostra altri 3 commenti
Aggiungi la tua risposta
Sam sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 69
