Asus ET2232I Not Powering On
I have an Asus LITEON WN6607AH-AD all in one PC. It is different from the one that I had to choose in the picture to the right, since IFixIt only had an option for something similar. I received it from a neighbor, and it doesn’t power on. I’ve managed to take it apart and do some diagnostics. I’ve tried pretty much everything I could think of, but it won’t boot. I think it might have something to do with a fried motherboard, which is a ET2232I Rev 1.2 board. I’ve looked online for replacement board, but it would be very expensive ($100+). If y’all have any ideas on what it could be or if you’ve had this problem before, then I would greatly appreciate your response. I’ve attached 2 pictures of the motherboard in case that would help.
Here is a list of the things I tried:
- Installing a ram stick (already has internal memory)
- Removing unnecessary cables from the motherboard
- Removed CMOS battery
- Tried 2 power cables
Questa è una buona domanda?
15 Commenti
You don't mention what diagnostics you tried.
Have you checked the power supply, for example? Is it outputting 19VDC?
da mike
Sorry. I have 2 different power supplies and I know for a fact they both work fine. I forgot to mention that the computer on the side I had to choose is different from the one I'm working on. IFixIt didn't have an option for my model. I'll try to add more info.
da Petabyte Studios
Still can't get it to do anything...
da Petabyte Studios
So it is completely dead?
No lights,
no fans spinning,
hard drive does not spin,
no beep codes sounding,
BIOS can not be loaded,
etc.?
da mike
It shows no signs of power. Not even a light.
da Petabyte Studios
Mostra altri 10 commenti
