Salta al contenuto principale
A singing, dancing, pink pony that responds to its included toys and outside stimulus.
4 Domande Visualizza tutte
Head/neck very loose and clicking
When I turn it on some of the moves it tries to do it clicks. Not positive what’s wrong but when it’s turned off the head and neck move around so I believe it’s either spring or motor there. I see the information for replacing motors or springs in legs but I believe it’s the head/neck. And where do I get the parts from to replace them??
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Risposta Più Utile
Upon dissembling the toy, I found one of the reasons why the neck clicks. there is a small plastic tab on the tip of the black neck coupler.
this slides into the potentiometer located in the white base of the neck
. This controls the rotation of the neck and prevents it from clicking. It got broken off. I got lucky and found the broken tab when I took apart the toy and managed to glue it back it on. I don’t know if the glue will hold. If it does not I will try and scan the base and see if I can 3d print it. I will make the .STL file available if need be.
Punteggio 2
Aggiungi la tua risposta
Jessica Hummell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 17
Tutti i Tempi: 395
