Salta al contenuto principale
Rilasciata il 15 settembre 2008 10,1 megapixel, zoom ottico 5x, LCD da 3,5 pollici, registrazione video HD
Camera Memory stick locked
Memory stick is locked. not able to shoot photo, nor i can delete photos.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Is there a lock switch on the stick?
da Condividi
Aggiungi un commento
1 Risposta
If you’re using the older style of memory card called the Memory Stick Pro, you should have a lock switch on the back of the card that might’ve accidentally gotten switched on. They look something like this (a red part of the switch will show if the lock function is turned on):
Immagine
However, if you’re using the newer Memory Stick Duo or Memory Stick PRO Duo card, it doesn’t have a lock switch, and that might mean that there’s something electrically wrong with the card or camera. If you have another memory stick you can try in the camera, you can check and see if the error still shows up.
Punteggio 0
Aggiungi la tua risposta
Umesh Kawalkar sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 21
Tutti i Tempi: 993
