Salta al contenuto principale
The QiCycle Folding Electric Bike is Xiaomi’s first foray into the world of e-bikes. It has a 250W high-speed motor powered by Panasonic 18650 lithium batteries. The Shimano Nexus 3-speed gear hub in combination with the torque measurement sensor gives you up to 45km bike power on a single charge. It also has a trip computer can connect to your smartphones via their special app and is–of course–foldable.
54 Domande Visualizza tutte
Why battery is 100% but display show me 0%?
Hello,
I don't know why but suddenly my qicycle stops to work… The battery is charged but the display show me 0%.
I tried some solutions like disconnect and reconnect torque cable and try to update by official and unofficial app the firmware but It doesn’t work.
When I try to upgrade the firmware, the process failed every time and I tryed few times.
I don't know really how to solve the problem, please help me!
thank you very much!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
I have the same problem. Did you find the solution?
Punteggio 0
3 Commenti:
I found it. In my case it is a broken cable into the ankle brake point of the cycle. I replaced it and it works just fine. Open the ankle and check the cables.
da
Can you help me? I have the same problem
da
Can pin point where is the ankle brake point of the cycle? Thank you.
da
Aggiungi la tua risposta
agrotheclown sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 19
Tutti i Tempi: 548
