Salta al contenuto principale
La Passat B6 venne presentata per la prima volta al Geneva Motor Show a marzo 2005 e lanciata in Europa nell'estate del 2005.
20 Domande Visualizza tutte
What is the issue?
what I noticed with my radiator fans is that it would run constantly on high if the ambient air temp sensor isn't plugged in but if I plug it in the fans don't turn on not even during cold start. All of the relays and fuses are operating but can't find the issue.
Questa è una buona domanda?
Punteggio 0
2 Commenti
@willx do the fans eventually turn on while you run the engine? What exact year and engine size is your Passat?
da
No they won't and it's a 2015 1.8
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I would take it to an AutoZone and get a free computer readout to try to isolate the problem.
Punteggio 1
Aggiungi la tua risposta
Will sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 147
