Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Domande Visualizza tutte
White screen after replacement, but differently.
I have gotten the famous white screen after replacing the screen, but this time it's a bit different. The screen only turns on when iOS boots up, and never shows the apple logo at all. I'm completely stumped by it because the original screen works perfectly well, it's just in horrible shape. The replacement worked fine when I first installed it, and nothing I've done, not even a restore, will seem to fix this issue. I've even tried the power+vol up+home combination and got absolutely nothing. I'm worried I'll have to refund the screen. If anyone has a solution to this I would appreciate it rather greatly.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Did you try another new screen already?
Punteggio 0
2 Commenti:
@douglasvinicio I haven't had the money to order another one, so no. I just have the replacement I already purchased and the original
da
In base of my experience if your original one is working,your motherboard and FPC connectors are fully functional. So i would assume that is just buy and install a new screen to solve your problem.
da
Sounds like the screen may be faulty? Get the manufacturer to replace it and see if that fixes it :)
Punteggio 0
1 Commento:
@ran9aa I will give that a go.
da
Aggiungi la tua risposta
SolarisTheBat sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 49
