Salta al contenuto principale
Modello metà 2010, A1278 / processore Core Duo 2,4 o 2,66 GHz
794 Domande Visualizza tutte
Why is my trackpad bulging out?
My Macbook Pro has the trackpad bulging out and i googled to see if i could find out the problem. lots of people said its the battery thats bad, but i was wondering if i also need to replace the trackpad or if it would still be good to use with just replacing the new battery?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
If the trackpad has not cracked it is most likely still good. But get that battery out before it does more damage.
Installazione della batteria nel MacBook Pro Unibody da 13", versione metà 2010
Punteggio 4
I’ve experienced this, and when the battery bulges like this, the trackpad will get bent, and would need to be replaced, because the trackpad internals got damaged by the bending.
Punteggio 0
Aggiungi la tua risposta
villa_cheli sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,857
