Salta al contenuto principale
Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
Stop switch assembly location
Yamaha G22A gas golf car, where do I find the Stop switch assembly
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
https://youtu.be/PNaeM_A6DcM
Make sure the stop switch is bad before replacing… check your fuses….
Punteggio 0
2 Commenti:
Fuse is good cart motor will not shut off except with key Ibelieve switch is jammed on. Need location of switch.
da
Found the switch it is under floor panel. Lift up floor mat underneath by brake & gas pedals is a floor panel lift it out switch is underneath gas pedal. All accessible from top of machine.
da
Aggiungi la tua risposta
Gib sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 430
