Salta al contenuto principale
Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
128 Domande Visualizza tutte
What is the normal charging voltage for the USB-C port?
I’m using a USB Type C PowerMeter tester from Jokitech to test the voltage passing through the charging port on a MacBook (Retina, 12-inch, Early 2016) that’s not charging or powering on. The reading I get is 5.13V / 0.00A.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
USB-C offers a few different voltages depending on what the device asks for. If you are using the original Apple charger you’ll see on the unit the following:
  • Apple 30W USB-C Power Adapter: 5V @ 3A, 9V @ 3A, 15V @ 2A, 20V @ 1.5A
  • Apple 29W USB-C Power Adapter: 5.2V @ 2.4A, 14.5V @ 2A
So your charger is working, the system appears not to be asking for power (no current draw).
  • Is the battery charged?
  • Is the cable you are using the original one that came with the system?
Reference: USB-C Power specs
Punteggio 2
Aggiungi la tua risposta
Zachary Lunte sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 132
Tutti i Tempi: 11,339
