Salta al contenuto principale
Lanciato il 22 settembre 2017. Modelli A1864, A1897. Disponibile in versioni GSM o CDMA / 64 o 256 GB / gold, silver e space gray.
678 Domande Visualizza tutte
iPhone 8 plus touch and freezing issues after screen replacement
I replaced the screen on an iPhone 8 plus with iOS 12.0 installed, a few days later the touch became intermittent, sometimes it works great sometimes and won’t respond. I updated to iOS 12.2 hoping to resolve the issue but the issue only got worse. screen sometimes would just freeze, I tab the messages app and it won’t respond after a few tabs now it works, screen is too sensitive, all apps could start to wiggle as if I touched and held an app longer that 3-4 second when in reality I barely touched it. I re-installed the original cracked screen and now it completely frozen, I installed a brand new screen and its still frozen. Please help!
Questa è una buona domanda?
Punteggio 1
2 Commenti
Hi Owen, thank you very much for your reply!
-I installed 2 new screens and it turned on frozen, I restarted the phone and it’s still frozen
-I went ahead and re-installed the original cracked screen it came in with, it turned on but it’s still frozen, I restarted the iphone and it’s still frozen.
- I now reversed the first screen replacement and i’m back to square one where screen works when it wants to.
I wonder if iOS 12.2 has something to do with it?
da
It might. Try doing a full restore by going into dfu mode and restoring it via iTunes.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Try replacing the screen. It’s probably just a faulty screen.
Punteggio 1
2 Commenti:
Have change the screen and the problem is still the same
My phone is hanging so badly
da
@beauty64950 start a new post with your problem. More people will see it.
da
i found this on my search, try it
'''iPhone 8 Freezing'''
Punteggio 0
First remove the Home button flex and check that also cause such issues.This phone have 3d touch too this section makes such a problem.This will help you to solve that problem.
Punteggio 0
Aggiungi la tua risposta
info sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,564
