Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Touchscreen does not work while on charge
I bought a 5s off of eBay for $20, not turning on or booting. I replaced that battery and dock connector, and it worked great. The touchscreen was fine and everything worked perfect. When I put it on charge though, the touchscreen is glitchy, touching apps will bring down the search bar and the scroll on safari is all messed up. When I take it off charge it works great tho. Any ideas?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
It seems to be the new charging port. When you charge the phone, thats when it activates the charging port the most. I would try reconnecting the charging port and battery connector and turn it on again to test the charger. If thats not the case than it must be a screen issue that was caused by the previous owner.
Punteggio 0
1 Commento:
Before going to all the work doing that, it also is worth seeing how well it works charging it using a different charging cable and/or wall adapter. Sometimes a cheaply made charger can interfere with the display's functionality. If it's not that though, it likely is something with the display, or the new charging port.
da
Aggiungi la tua risposta
Andrew Coppola sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 33
