Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
iPhone 6 PP1v8 powerrail
Hello.
I have a iphone 6 with weird value on PP1v8 power rail.
It should show 1,8 V but it is showing 2,70 V . Does anybody have similar issue ?
DCPS show’s 0 Amp’s before powering it up.
PP_VCC_Main - OK
PP_BAT_VCC - OK
DCPS after pressing power button constant 0,22 Amp.
Questa è una buona domanda?
Punteggio 0
1 Commento
Diode mode shows a good value as 339 ( ZXW shows 313), this small differenece cant be issue ?
Measured the cap near to nand.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Is it showing image or taking charging current through a usb amp meter
Punteggio 1
4 Commenti:
Hei,
From the board right now is missing Tristar, Backlight IC and Display IC.
Should it be still showing normal values on PP1v8?
da
I would replace the 3 to see what happens after
da
But still - Shouldnt the PP1v8 still be 1,8 Volt's even if these chips are missing.
da
What component are you testing for 1v8
da
Some where 3v connect to 1.8 that value shows 2.7.I also faced the same problem but i can`t solve it.I think under layer of the phone is shorted i think.
Punteggio 0
Aggiungi la tua risposta
Kaspar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 107
