Salta al contenuto principale
The eMac was an all-in-one G4-based Mac designed for the education market and released in April 2002. It was the last Mac to use a CRT display and was sold at a low price to schools and other institutions.
47 Domande Visualizza tutte
No Sound Coming From Speakers
A few days ago. I played music too loud (at the max volume). It was working fine. But now, the eMac chimes but the internal speakers don’t show up in control panel. (I am running Mac OS 9.2.2, and yes it is a 700Mhz eMac, so it is compatible!) I only have Mac OS 9 installed at the moment.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There is very little which you can fix on this system. As the sound preferences are not showing up I would try resetting the PRAM Reset NVRAM or PRAM on your Mac and given the systems age you may need to replace the PRAM battery eMac PRAM Battery Replacement
If that doesn’t work you damaged the DAC logic on your logic board. Which would need a new logic board.
Punteggio 2
3 Commenti:
I have a spare battery that I think would work with the system I am going to try and replace the PRAM battery.
da
This is a 1/2 AA 3.6 volt lithium ion battery.
da
Yes that is the battery I have I think
da
Aggiungi la tua risposta
Owen Ready sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 159
