Salta al contenuto principale
Impara a conoscere le competenze di cui potresti aver bisogno per lavorare sul tuo dispositivo.
Non-ESD mat, used with a ESD mat.
I recently bought a silicone soldering mat that has notches and grooves and it really helps with organizing my work space during projects (mostly phone repairs) . But I did some research on the mat and found out it was not ESD safe. So, my questions is that if I did buy a ESD safe mat, would it be okay to use the non-ESD safe mat on top of it.
In other words, ESD safe mat on the bottom, and silicone non-ESD on top. Would there be any static electricity generated.
Thanks, for the help. New.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sadly you still run a risk even when you have an antistatic mat under it.
As an example if you take a ballon and rub it on some cloth so it builds a static charge. The charge is strongest at the location where you rubbed.
Why don’t you use some anti-static spray on it before you use it to be safe.
Punteggio 2
Aggiungi la tua risposta
Juan Lopez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 559
