Salta al contenuto principale
Laptop does not turn on but some LEDs light
Hello.
My low-end ZedAir laptop (it has non-removable battery) does not turn on and been trying to turn it on by the power button for hours.
I can’t figure out the real cause or factor that caused it unusable.
Maybe it is caused by the broken power button, or maybe the battery or maybe even the OS because I was able to open it before with the same issue, and LEDs are lighting up for 1 second after it was plugged in. Please help me!
Any help will be appreciated. Thank you!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Without proper diagnostics and tear down it is impossible to say 100% what is at fault, however one strong candidate is the battery has malfunctioned, this can also happen when they go totally flat without recharging for long periods. When batteries malfunction they tend to disrupt the power up sequence. Unfortunately your battery is non removable. If you are handy you could open it up and unplug the batteries from the board and try it again.
Punteggio 0
Aggiungi la tua risposta
PocketKent - Minecraft sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 49
Tutti i Tempi: 2,430
