Salta al contenuto principale
Guide per la versione Wi-Fi dell'iPad Mini 2. Annunciato il 22 ottobre e introdotto il 12 novembre 2013. L'iPad mini 2, noto anche come iPad mini con Retina Display, ha tutti i pixel dell'iPad Air in un più piccolo fattore di forma da 7,9"
20 Domande Visualizza tutte
recently replaced digitizer issuse
So, i recently replaced a digitizer not from ifixit.
and it worked for a few seconds but stopped working completley after a few good seconds home button was not working too. i opened up the mini again and inspected it. No issuses whatsoever and put it back on. digitizer and home button is not working at all. should i sell it for parts?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Did you have the same issue before replacing the digitizer? I suspect that replacement digitizer is defective, try another known working digitizer to confirm.
If issue persists, then you need someone with micro-soldering experience to fix as this is board related.
One thing I want to point out that the Mini/Mini 2 replacement digitizers are notorious for ghost touching (iPad activates itself erratically), make sure you cover the bottom strip near home button with Kapton or any ESD tape.
Punteggio 1
1 Commento:
the old digitizer has the ribbon cable ripped out making it useless
da
Sins you didn’t buy it from ifixit i am assuming the quality was bad and thats why this happend. Do you still have the old screnn if you do try to see if it turns on. Is it recognized by iTunes?
Punteggio 0
3 Commenti:
the old screen is done beacuse i got it the ipad for free and the ribbon cable is gone for the old digitizer
da
it is recognised my itunes
da
Okay so just buy a new one from here and it should work
da
Aggiungi la tua risposta
Zander Castillon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 71
