Salta al contenuto principale
The Wonderboom is a Bluetooth portable speaker from Ultimate Ears. Released in 2017. Model number: 984-000839.
37 Domande Visualizza tutte
My Wonderboom is frozen.
Today my UE Wonderboom suddenly stopped working, however it will not power down. The power light blinks but it will not turn off, pair, or anything else. I tried the factory reset, and it will not work. Can anyone help, please? Thank you!
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
3 Risposte
Soluzione Prescelta
I just spoke to UE customer service. I had to perform what is considered a “hard reset”. Press the volume up (+), volume down (-), the power button, and the Bluetooth button for about 15 seconds. My speaker is now back to normal. I hope this helps someone who might have the same issue.
Punteggio 12
9 Commenti:
I was wondering how to do it on the WonderBoom, good info!
da
Thanks had the same issue and it worked !
da
No problem! I’m so glad it worked for you!
da
Hey, I'm having the same problem. I accidentally charged my wonderboom for10hrs. Now power and Bluetooth lights are ON. Tried reset and hard reset. But still it's not working. When I press volume up (+), volume down (-) and bluetooth button together, the lights go off and again back after releasing.
da
Exactly same thing has just happened to me, did you resolve it in the end? If so how?! Many thanks!
da
Mostra altri 4 commenti
I would contact UE, hopefully your warranty is still valid!
Punteggio 2
Wow this actually worked. Thank you so much for
Punteggio 1
Aggiungi la tua risposta
Christopher Osborne sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 108
Ultimi 30 Giorni: 458
Tutti i Tempi: 17,098
