Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
itunes Error 1013 Help?
Using the instructions on this link to fix the 1013 error its says to Delete all line that has "gs.apple.com" or something like that and save it but it wont let me save after making changes how do i save it?
http://www.redmondpie.com/fix-itunes-err...
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Jared, not sure which OS you are using, I just used Win Xp and opened the file hosts at Windows/System32/drivers/etc with notepad. where it says Filenamw "*.txt" I changed it to "*.*" which shows me all the files. Now I click on "hosts" It opens it up and shows me all the line items. here I delete all the ones that show ""gs.apple.com" Once they are all deleted, I go to the file menu and select save as "hosts" Now, when notepad saves it, it automatically adds the ".TXT" extension. I close notepad, go to the "Windows/System32/drivers/etc" directory and right click on hosts.txt select rename and delete the ".txt" extension. Now the file is saved as the hosts file. Hope this will help Good Luck
Punteggio 3
Aggiungi la tua risposta
Jared sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 766
