Salta al contenuto principale
Modello A1502 con processore Intel dual core da 2,4, 2,6 o 2,8 GHz. Sul mercato dall'ottobre 2013.
552 Domande Visualizza tutte
Screen late 2013 broken compatible 2015
Hello everyone,
M’y screen on my 2013late mackbook is broken.
There is a chance that I bought a screen practically for free but it’s a 2015 screen , someone know if it can be replace by this model ? I don’t find any thread about it ….
thank in advance for any suggestion.
John
Bonjour à tous mon écran de mackbook est cassé en cherchant désespérément j’ai trouver un écran de remplacement pas cher, mais il s’agit du modèle 2015,
Je ne trouve aucune information pour savoir si ils seraient compatible ou non, quelques idées ?
Merci par avance , John
Questa è una buona domanda?
Punteggio 0
1 Commento
I’m using one on my 2013, works fine but when I close the lid it doesn’t sleep.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
No. While the 2013 display will work on the 2013 & 2014, it will not work on the 2015.
MacBook Pro 13" Retina (Early 2015) Display Assembly
COMPATIBILITY
  • MacBook Pro 13" Retina A1502 Early 2015
Immagine MacBook Pro 13" Retina (Early 2015) Display Assembly
Prodotto
$449.99
Punteggio 4
2 Commenti:
The questionnis will the 2015 screen work on 2013 model... (retrofit)?
I can understand that the ‘13 will not work on ‘15 model..
da
@tiggger71 - No it won't work in that direction either!
Just like how gasoline won't power a diesel engine or how diesel fuel won't power a gas engine.
da
I’m currently using mid 2015 Retina screen on late 2013 MacBook Retina. It works fine, I get brightness on apple load bar screen, web camera works. However, display brightness cannot be changed/adjusted (nothing happens) until you put the computer to sleep and wake it up. After that, brightness control works fine.
Punteggio 1
2 Commenti:
So it is possible to put a 2015 screen on a late 2013 MacBook Pro?
da
@clown2joker - Sadly d0d0p is sending you in the wrong direction!
Let's look at this from a parts perspective why would Apple (and the parts sellers) make is clear they are not compatible parts? These are very different generations of displays! This gets into the signaling these displays use eDP connections vs iDP connections
Apple jumped from one to the other. So as I tried to express above "Just like how gasoline won't power a diesel engine or how diesel fuel won't power a gas engine." Thats what you are facing here.
Bottomline: Use the correct display for your system!
da
Aggiungi la tua risposta
Johnny sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,157
