Salta al contenuto principale
Il tablet Surface Pro di sesta generazione, lanciato sul mercato a ottobre 2018. Disponibile in platino e nero. Numero di modello: 1796.
31 Domande Visualizza tutte
Can I use the display unit of the Surface pro 5 for pro 6?
Hi,
can i use the Display of the pro 5 to fix my shattered Pro 6 Display?
Questa è una buona domanda?
Punteggio 2
1 Commento:
I'm going to give a tentative "yes" with the caveat that I'm not speaking from direct experience.
Looking at pictures of replacement screens for both the Pro 5 and Pro 6, the cabling looks to be identical. The specs (resolution, physical dimensions, etc) for the screens are also the same. I also found part number "LP123WQ1 SP A1" being sold on eBay as a replacement screen for the Surface Pro 6 *AND* the Surface Pro 5.
da
Aggiungi un commento
1 Risposta
No you can’t, the Surface Pro 5 and Pro 6 displays have different touch controllers and are not cross-compatible.
Punteggio 0
1 Commento:
I have installed the pro 5 display on a surface pro 6 without issues. I’m not sure sure where you got your info from but they are 100% cross compatible.
da
Aggiungi la tua risposta
ykf kaanf sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 30
Tutti i Tempi: 1,719
