Salta al contenuto principale
Modello A 1297 / Processore Intel Core 2 Duo da 2,66, 2,8, 2,93 o 3,06 GHz
Front Bezel- Frankenstein Replacement?
Has anyone tried replacing the front bezel of a non-unibody macbook pro 17 " with the front bezel of a G4 powerbook 17"?
From pictures the strucutre looks similar, however, there may be two potential issues: the camera and the hinges.
Please let me know if you had any experience with this frankenstein fix or know if it might work, thanks!!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
I've looked through the manuals for both and I will agree that they do look VERY similar (front, back and overall dimensions). I do not have both at my disposal so i cannot tell you if they will work or not. I would be curious of your results. The hinges shouldn't be a major issue, the camera might cause problems (as you also mentioned). You might have to dremel off some mounting tabs and use two sided tape to hold it in place.
Punteggio 2
Well, i think that needs some serious home engineering ;-)
As pierrej mentioned, a Dremel would be of tremendous value.
Punteggio 1
1 Commento:
Thanks for the help guys! However, I chickened out of the experiment..finally found the piece online : )
da
Aggiungi la tua risposta
Dagrosap sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 646
