Salta al contenuto principale
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
Is there a way to clear a control panel malfunction?
Machine stops mid-cycle. Sometimes I have been able to simultaneously press and hold power and start and the error seems to clear but not working.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Unplug the machine for five minutes to allow the control panel to reset. What are the error codes you are getting?
Punteggio 2
1 Commento:
I unplugged the machine and after plugging it back in was able to finish the load. It quit again in the middle of the next load. I unplugged the machine, but when I plugged it back in it was still stuck. I pressed power and start simultaneously, and was able to start the next load. We’ll see. I do not see any error code.
da
Aggiungi la tua risposta
Bruce Haffey sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 91
