Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Why is my iPhone in a boot loop and then goes in to a red screen
How do I fix my iPhone5s that is in a boot loop and then goes to a red screen and then goes back to the apple logo and it has to be plugged in to event turn on
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Could be many things, can be caused by:
  • Bad front camera assembly, perhaps cable got torn after drop, if unplugging cable lets the phone boot that is the case
  • Bad Tristar / charging chip, can happen can be confirmed if apple logo does not appear with charger plugged in and battery unplugged. Will require someone with micro-soldering experience to replace chip on board.
  • Corrupt Firmware / Software restore will fix this
  • Bad CPU / NAND / Baseband = Unfixable pretty much.
Punteggio 3
1 Commento:
Are the replacement logic borders from ifixit good ?
da
Has the screen been replaced? This could be something like ''Long Screw Damage''
Try to put it in recovery mode and update it, it might give you an error code that gives you some clue.
Also, what is the history? what’s happened for the device to be in the condition it is in?
Punteggio 0
2 Commenti:
I don’t know if the screen has been replaced but it stoped working when I dropped it but the highs was not that high
da
The error is a error 3014
da
Aggiungi la tua risposta
Jayden sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 88
