Salta al contenuto principale
Lanciato il 3 marzo 2017, Nintendo Switch è un dispositivo palmare che può essere usato con la TV o in movimento.
705 Domande Visualizza tutte
wont charge need more info
i have a nintendo switch at my store that isnt charging. i think its a bad resistor because im reading OL and no power is getting past. can someone tell me the proper value for the resistor right next to the number 6 in pic?
http://puu.sh/D2OMV/1562e70915.jpg
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Have you changed the charging port as that would be more like the problem
Punteggio 1
1 Commento:
problem isnt the charge port. i looked at the inside of the port under a microscope and it looks brand new no bent pins. also i touched up the solder joints on the port to make sure there was no cracks. 5volts is getting to the resistor but 0 on the other side. and it should drop it down to 3.2volt. like i said the resistor is OL and no power is passing. so i know the problem is that component, i just cant find any service literature to find the proper resistance.
da
Aggiungi la tua risposta
lukerockhill sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 71
