Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
iPhone 6 sometimes not ringing with iOS9
So my Problem is with iOS9, that my iPhone 6 is sometimes not ringing. Its sporadic and - i think - only with Numbers, that are in the Call History or under Contacts, then the iPhone is only vibrating verry short for one time, the Display is dark and it makes no noise. If i press the Home Button i can see who calls me.
So i think it must be a Bug, because in 95% everything works fine and with iOS 8.XX i never had this issue.
When i tried to reproduce the Problem, i called my self a few times and sometimes it was ringing normally, and a few time i had the issue that there was only a short vibration with a turned off display.
I reseted all Settings a few times, but it did not help. Anyone had the same Issue?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Try resetting the phone.
Punteggio 0
If your calls are malfunctioning but the rest of your phone works fine, then the problem may be your calling app. Please see if these fixes won’t help-
  1. Try uninstalling and then reinstalling the phone call app. Doing this will also update the app.
  2. Try using a different app for phone calls.
Punteggio 0
Aggiungi la tua risposta
roroeow7 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 72
