Salta al contenuto principale
Versione maggiorata del top di gamma Samsung rilasciata nel marzo 2018.
130 Domande Visualizza tutte
Cell phone won't connect to 4g only when it disconnects from my home
Samsung and At&t can’t solve this problem as my phone will not connect to 4g when I leave my home. It disconnects from home wifi and then will not connect to 4g unless I turn the phone off or airplane mode on and off. My home wifi is the only wifi this happens with as when in another wifi area where phone is connected it has no problem connect back to mobile data or 4g.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Try navigating to Settings  > General management > Reset and tap Reset network settings. That will reset your network settings and hopefully solve the problem. Note that this will erase Wi-Fi passwords, and probably Bluetooth devices (not sure, can’t test at the moment).
Punteggio 0
1 Commento:
Thanks, have done that more than once and reset the whole phone which takes everything away and Samsung even replaced the phone and I'm on my 3rd phone. It only seems to happen when I leave my home wifi that it won't connect to the mobile networks by auto meaning I have to turn the phone off and then on once outside the home. Thanks.
da
Aggiungi la tua risposta
pahogg sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 64
