Salta al contenuto principale
La linea di computer portatili MacBook Pro di Apple per utenti avanzati e professionisti. La linea MacBook Pro include varianti da 13, 14, 15, 16 e 17 pollici, e le revisioni principali sono definite da Pre-unibody (originale), unibosy, display Retina, Touch Bar e SoC (system-on-a-chip).
20012 Domande Visualizza tutte
820-2936 quarter fan spin
so to start out i dont specialize in mac repair, i mostly work on phones. but a friend of mine had an issue with their macbook so i figured id take a look at it.
so everything is disconnected but the board and dc in board. it shows a green light on the charger and fan starts to spin up then stops. i checked all the main power rails and i found one that isnt right. pp5v_s3 is missing and its weird, when the fan starts to spin it shows 5volts for a split second the 0 again, and if i hook power to the board then disconnect power and test the line is shows as .006 voltage drop in diode mode but if u keep the multimeter probes on it starts to rise until its at like .400 i went over the entire board under a microscope many times and also looked at it with ir camera. i dont see anything that looks terrible. but im stumped and am hoping one of the experts on here can point me in the right direction.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
You’ll need to spend sometime reviewing Louis Rossmann’s YouTube channel as he has documented a few different causes for your problem with a bad pp5v_s3. Get the schematics & board views so you can follow what he does and what trace or component needs to be repaired/replaced.
Punteggio 0
2 Commenti:
that was step 1...lol
da
@mobilemedic - Step 2 is not down voting a fair answer!
Your expectation is we can tell you what competent has failed, thats just not humanly possible from afar. If I had your system in front of me I would take the exact steps I outlined to you.
Debugging a board is a process using the documentation and test gear to isolate out the failing component.
da
Aggiungi la tua risposta
lukerockhill sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 10
Tutti i Tempi: 627
