Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
Camera problem after screen replacement
Hi!
I replaced the screen for iPhone 6s plus. Now the cameras arent working. If I havent plugged the front camera connection in, then the both cameras are black. If I disconnect the front camera the rear camera starts working fine.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
If rear cam works after disconnecting front cam then you’ll need to replace the front camera assembly. Most likely due to a torn flex.
Sostituzione gruppo fotocamera FaceTime e sensore dell'iPhone 6s Plus
iPhone 6s Plus Front Camera and Sensor Cable
Immagine Replace a front camera and sensor cable compatible with the iPhone 6s Plus. Includes the front camera, secondary microphone, ambient light and proximity sensors. Part #821-00153-A.
Prodotto
$55.99
Punteggio 0
1 Commento:
So you think this is not a board issue? Will 6s camera work, I have one laying around?
da
Most likely you damaged the front camera assembly during the repair. This can be a hard piece to remove if you don’t have a lot of experience. Did you just pull it off the old screen? In the future, a little heat will help loosen the adhesive.
Punteggio 0
Aggiungi la tua risposta
Lauri Pahkala sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 178
