Salta al contenuto principale
Repair guides and support for Kenmore washing machines.
Kenmore washer error code
Error code OL for a kemore washer model # 27052600
Questa è una buona domanda?
Punteggio 0
1 Commento
This question was migrated from https://meta.ifixit.com/Answers.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
sharrybaseball The OL error code indicates that the washer is overloaded. If the washer is not overloaded, this could indicate either a drag on the drive system or the control board is failing. Empty the washer and spin the basket to check if it rotates freely. If it does not, then something may be caught between the spin basket and the outer tub which could give you an OL code. Also check for any obstruction underneath the washer by the motor that could be interfering with the motor. If you do not find any problems with the spin basket, then there could be a problem with the tub bearing, or worst with the control board or the motor.
Going by your number your washer is a 110.27052600 Kenmore Elite Oasis
Punteggio 2
Aggiungi la tua risposta
sharrybaseball sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 79
