Salta al contenuto principale
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Domande Visualizza tutte
Need help reinstalling os x have tried everything.
So i stupidly wiped my hard drive of everything. Now i get the flashing folder on start up and I’ve tried every control possible to get it to boot to disk utility, network install won’t load when i press N on start up the globe symbol flashed like 4 times then the ? folder will appear, Tried to boot off usb it can’t find the usb. Thought i may have damaged the HDD when erasing it so i bought an SSD. I formatted it to HFS+ on my windows computer so the iMac would recognise it but i’m getting the same results as before.
I have literally tried everything, every command, every way to boot and still nothing.
This apple is about to become a pear when i throw it out the window!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You'll need to create Mac os installation media on a Flash drive to reinstall Mac os but that requires another mac in order to do so.
https://support.apple.com/en-au/HT20137
Usually internet recovery should work from the following:
To manually start up from macOS Recovery over the Internet, press and hold Option-Command-R or Shift-Option-Command-R at startup
Punteggio 2
Aggiungi la tua risposta
15th Junction sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 384
