Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
iPod will not charge and is not recognized by Itunes
i have an ipod touch 4th gen, and it does not charge.  it is strange to me though because it plugs into speakers through the charging port and works fine, but it does not stay on.  then when i try to charge it, it shows the "its dead" charging symbol, so it is charging. but then when it turns back on, it does not continue charging
i have also used several different cables in case it was a cable issue; i even bought a new one. but that did not help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Have you checked the 30-pin connector (where you plug the cable)? Make sure it’s clean and there are no broken or bent pins.
Punteggio 0
You need to replace it.iPod Touch 4th Generation 30 Pin Dock Connector Replacement
Punteggio 0
Aggiungi la tua risposta
Randi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 97
