Salta al contenuto principale
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Domande Visualizza tutte
Switch Unibody From MacBook Pro to MacBook
I have a Mac Book Pro with a Broken Screen and keypad. I also have a Mac book that everything is fine on. Can I switch all the internal parts on the Mac Book Pro and make them work in the Mac Book A1278 Unibody?
Questa è una buona domanda?
Punteggio 0
1 Commento
Mac Book Pro has a SD card port. Mac book does not
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Are they both A1278 model MacBooks? If yes the keyboard is switchable. The screen however will are not compatible if they are too far apart from the years. You’ll be able to tell once you open the bottom of both of them and look at the display connector. Both ones should have the same connector and latch on the cable.
Punteggio 3
Do still need help with your book?
Punteggio 0
Aggiungi la tua risposta
Bruce Spafford sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 59
