Salta al contenuto principale
Repair guides and support for laptops manufactured by MSI.
269 Domande Visualizza tutte
MSI GL73 8RD-201 Chassis removal
Does anyone know how to safely remove chassis from MSI laptop GL73 8RD-201 without damaging plastic tabs?
I’m confident I can just force it off but I dont want cosmetic damage on this particular one since it’s my friend’s.
Thanks much!
Questa è una buona domanda?
Punteggio 0
2 Commenti
Thank you for the reply
I should have mentioned that my issue is the step immediately following the removal of the screws.
I guess there are tabs holding it together on the edges.
Trying from the palm rest never crossed my mind.
Thank you for giving me a new angle!
da
Did this work? I'm currently trying to open mine and cannot figure it out
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I watched a youtube tutorial of a similar laptop.
Remove the screws at the bottom.
Use credit card or guitar pick to pry between hte edges.
It is as simple as that but I haven’t found a way to guarantee that the tabs wont break.
Maybe a heat gun or something to soften the plastic will allow it to flex rather than snap.
Otherwise this works to open it.
Thanks everyone.
Punteggio 0
Risposta Più Utile
MSI is difficult as they do not provide any servicing details to the public and expect you to service it through an MSI authorized shop. Have you already taken all of the screws out of the back and separated the palm rest from the bottom panel? Gaming laptops tend to be a little misleading, with things such as hidden screws, or something that slides in a clip weird. Also, it's common to have a skeleton that everything attaches to from both sides as well as a palm rest and bottom panel.
Punteggio 1
Aggiungi la tua risposta
Daniel Goranov sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,401
