Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
Made a slight mistake with my battery, should I replace?
In changing my phone screen, I noticed that my mute switch screw was loose. In trying to tighten it up as carefully as I could, my screwdriver rubbed against the battery, exposing the metal shielding ever so slightly. Am I safe here, or should I swap out the battery?
Update (03/02/2019)
Hope this clears things up. :/
Update (03/02/2019)
The battery doesn’t appear swollen to me so I am still of two minds about it. Here’s a better image:
Questa è una buona domanda?
Punteggio 0
2 Commenti
Cheers! It's not overly expanded but it is still.
Really it's a hit or miss as you say, but as a safety precaution I would still change it out.
da
Thank you for your help, I am going to replace the battery as advised. Thanks :)
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
To be on the safe side it would be recommended to change the battey it's hard to say with out seeing it.
It's most likely just scraped the top and is fine for now, but if you drop your phone again and its sparked it could trigger of a burn.
Punteggio 2
3 Commenti:
I posted a picture up above. It does look very slight, do you think I should change it?
da
Thanks for the pic! Seeing that battery and that nick in it I can also see that your battery has expanded and I would definitely change it.
Make sure you use the pull tabs to remove that battey so it doesn't explode.
da
Darn, I was hoping it wouldn't come to that! It doesn't look swollen where I can see, I've attached a better photo below :)
Thanks in advance
da
Aggiungi la tua risposta
chrisjohnlarkin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 66
