Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Weird grey lines on starting screen, in system blue lines.
Hi there, can anyone help me ? I have here friend’s iphone 6 - i replaced him screen around 6 months ago and yesterday he call me that on screen start appearing weird blue lines and when he turn off and then turn on a phone he have weird grey rectangles on the side’s of apple logo - here you have screen https://ctrlv.cz/0Ok5 - and here’s video how it look’s like in system - https://youtu.be/EpWdWK_Lh6M . ( sorry for my english, i hope you can understand it )
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Hi there!
I would suggest the following:
  1. Disconnect/remove the display.
  2. Inspect the display ribbon cables for any pinches or tears and inspect the connections and contacts on the logic board for any damaged pins.
  3. Use a Q-tip dipped in Isopropyl/Rubbing Alcohol to clear out any debris in the connections and contacts.
  4. Re-secure the display connections and reseat the display.
  5. With the new screen installed, power off the device and let it sit untouched for at least 6 hours.
If this doesn’t help, it is possible that some sort of damage did happen during the repair or pins on the connections on the display or it could simply be a bad display. Hope you are able to figure it out though!
Punteggio 1
Probably just a bad LCD but you might be able to reseat the lcd ribbons. Most likely a screen replacement.
Punteggio 0
There is a chance that the new screen for the iPhone 6 was not replaced properly, and your friend might have done something to dislodge it accidentally.
It might be best to take the iPhone to a shop and have a technician replace the screen.
Punteggio 0
Aggiungi la tua risposta
- Ungeros - sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 116
