Salta al contenuto principale
Rilasciato a luglio 2018, il MacBook Pro da 15", modello A1989, adotta uno schermo retroilluminato a LED da 15,4" con tecnologia True tone, Touch ID e processore fino a esa-core Intel Core i9.
203 Domande Visualizza tutte
Will my touchbar go out?
I dropped my charger on the end of my touchbar and its kind of dead towards the end. Will the whole thing go out before i can get it fixed? How much would this repair cost? Im trying not to press so hard on it or slam the screen down. Everything still works even Siri even though you cant see it.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Well good news! You don’t need to replace the uppercase at all, you only need to replace the TouchBar its self!
MacBook Pro 15" Retina (Late 2016-2017) Touch Bar Assembly
Its still a big job so you might want to find someone better skilled.
Immagine MacBook Pro 15" Retina (Late 2016-2017) Touch Bar Assembly
Prodotto
$39.99
Punteggio 2
Hello,
Shortly : no it shouldn’t break even more. The Touch Bar is attached to the keyboard, so Apple will change the battery, keyboard and Touch Bar (the hole bottom assembly of your Mac actually). This should cost around 600$. From what I see in your photo, and from what you say (it still works), I don’t think paying for a replacement would be a great idea. Wait for your keyboard to get stuck (keys can get stuck easily on these models), and let Apple repair it for free (they repair this issue for free, changing the hole bottom part, so the Touch Bar also).
You can find the keyboard free repair program here : https://www.apple.com/support/keyboard-s...
Punteggio 1
1 Commento:
@talerant - I don't see Apple fixing this for free, unless Keja got AppleCare + and they will still charge a fee as it was damaged, not a parts failure even if the keyboard fails at some point, they will argue the keys got damaged at the same point.
da
Aggiungi la tua risposta
Keja Wynn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 144
