I need to clean the speaker holes
Hi every one, i have one plus 6T, i have spoiled a hot liquid candle wax on it, and i was able to remove the damage from the screen (thanks to the screen protector) now am left with only 3 holes for the speaker to listen from (the rest is blocked with the wax), i have tried to apply some heat from the hair dryer with no luck, what do you think is the best way to solve this issue ?
Questa è una buona domanda?
1 Commento
Hi Raving,
thank you for your answer, i had tried to do this but it didn’t fix it, even i applied heat using a hair dryer then i used the needle, but the surface area is so small that the wax will be hard again while am trying to apply the push through the needle
da Abdullah Al Rawi
