3GS Volume and Power button Rattles
Hi All,
New to the site, but used it for a recent Iphone 3GS back cover replacement & home button fix.
I have because of the above had the phone totally disassembled and when putting it back together, the power button is sunken, the volume buttons rattle and the mute button feels different (not quite sitting correctly).
Is there something I'm missing? I was extremely careful during reassmble and have made sure all screws are in the right place (I think!).
Any advice would be great.
Thanks,
Andrew
Questa è una buona domanda?
3 Commenti
New replacement iPhone 3g/gs cases have variances that cause difficulty fitting basically every part from the bezel, buttons and even the SIM tray correctly. OEM does not mean it was made by the same Factories that Apple sources its Parts from. Unless you used a Real Original iPhone Case for replacement consider yourself lucky if everything works.
da Brad
Thanks for the response Brad, much appreciated.
What would be your advice? Scrap the one I have purchased and buy a genuine?
da Andrew McMillan
if the power button doesn't fit in the case opening properly you could try filing it a little with fine sand paper, the ring does sit toward the bottom and sits on a small ledge in the rear case. don't over tighten the screws or you may not have any play in the button.as for the headphone jack.. take a look at the under side- it has a "tab"? (for want of a better word) that makes it sit flat. you need to slide the jack first then place into opening. the volume control is a PITA..fiddly as anything! it may be that the holes in your back case aren't deep enough or you haven't tightened the screws? trial and error..sorry.
da pollytintop
