@hellomacos hey. So I’ve gotten the casing apart and the wires separated. Pretty interesting
These are the important notes so far
The connector to the motherboard I did t expose all the way but from the “tear down” guide. It seems to come apart one more time? Not sure, it’s a small connector that plugs in up and down not in and out
. After further investigation. I see that it does not. Also I discovered that some of the metal I thought was insulation. Was actually a wire. That’s good news lol.
21-22 wires
I may need to micro solder the wires back together and re insulate wrap and shrink cover it I don’t see myself throwing any caps on these small wires.
Any suggestions?
@hellomacos i just realized that’s exactly what you said to do lol!!!
Here is a better photo I actually took it apart more slowly this time. 2 sets of 2 wires are wrapped separately. 1 bundle of wires is wrapped separately. And the more metallic looking wires are exposed.
Here is a photo of the soldering workstation I purchased
I wasn’t able to do a reply and add photo
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
3 Commenti
Yeah I’ve had a vr headwear for almost 2 years that a dog chewed up, if the wires are soldered to the internal board you might be able to sweat all the wires and re solder them. I’m going to attempt to tear it down and see what it looks like, find a similar strand of wire in a harness already and try to re run the harness somehow. The wires are so small there does not seem to be any way to fix them individually m.
da Chris Vienola
I watched a very good video on YouTube of someone actually replacing the cable with a new one, but I can't find any place that actually sells this cable. Most of the ps4vr headsets for sale on eBay sold "for parts only, not working" have the same problem - the cable is broken. Does anyone know where to buy the cable?
da Shannon Forsyth
Has anyone found a source for PSVR2 cables - they have a non standard USB-C like connector on the headset end. Or if anyone has a wire color to pin on the standard USB-C free end, I would be most appreciative! I have a USB-C 3 breakout board I can work with if I know what wire color goes with what function. Worse case I will have to go through the pins one by one (if I work this out, I'll post it here.)
da lrshapiro
