Salta al contenuto principale
The Shark Rotator NV502 vacuum was made in 2013, weighs 15.5 pounds, and includes a lift away handle. The vacuum can be used on both carpet and hardwood floors.
19 Domande Visualizza tutte
I need a new elbow clip?
The clip that attaches the elbow to the body of the vacuum and the hose is broken off. I Need a new one and can not find it in the parts lists. Whats it called and am I able to buy a new one?
Questa è una buona domanda?
Punteggio 6
13 Commenti
I have the same problem. Did you find a fix for it?
Thank you,
Geri
da
I have the same problem. does anyone know where to get one?
da
I used one thicker zip tie and it works beautiful; great tip, thanks so very much!
da
The zip tie works perfectly! Thanks for the engineering tip!
da
Thank You for the Cable Tie/Zip tie tip. It has just happened to us.
da
Mostra altri 8 commenti
Aggiungi un commento
8 Risposte
Risposta Più Utile
Same happened to me and I wound up using two zip ties to secure it in place. Works just like normal.
Punteggio 6
3 Commenti:
I see you used zip ties does it work?
da
Thank you for sharing this!
da
great! thank you.
da
I found some on eBay for $8. It’s called a lower hose latch on there.
Punteggio 2
Shark doesn’t sell a replacement. I designed one and put it up on eBay for $8 plus shipping. I send two pieces (since it’s easy to break it while installing) and a replacement spring, since those tend to go flying. People seem pretty happy with them.
https://www.ebay.com/itm/124766956799
Makes me mad when companies don’t sell a replacement for small, easily breakable parts on relatively expensive items. Just adds to the landfills.
Punteggio 1
1 Commento:
Did you put the zip tie where the spring would go from the red clip?
da
There is someone on ebay who apparently made the piece and sell them for $8.00 plus shipping. However I also used a wide heavy zip tide and it works perfectly.
Punteggio 1
2 Commenti:
Speaking of which, did the part work for you, Major?
da
Hey, did you put the zip tire where the spring went or what did you place?
da
The clip without the spring actually worked and held the elbow in place I would use it in combination with a zip tie to insure the elbow seats properly
Punteggio 0
It’s called a rear hose swivel valve and latch.
Shark does not sell it. Found it used for 40. Knock off for 28. Crazy prices. Have not purchased.
Update (01/10/2020)
this is the item
Punteggio 0
2 Commenti:
I used gorilla tape but am now going to add a zip tie
da
@kak708 will not buy from shark again if I cannot get parts to fix it, mine broke also I do not like to half ass fix things.
da
Hose reel swivel spring. Took me days to find out what that part was called
Punteggio 0
So my red clip broke and when I ordered it, I thought I was ordering it. They sent me the whole elbow attachment so as I’m trying to put the new attachment on thinking, I don’t need the clip. I’ve taken the middle spring and the middle piece of the inside of it came off I don’t know how to put it back on ultimately how do I replace the red clip or rig so that it works thank you.
Punteggio 0
Aggiungi la tua risposta
julie0000davis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 83
Tutti i Tempi: 7,754
