Salta al contenuto principale
Modello A1419 / EMC 3070 / Metà 2017 / processori Core i5 3.4, 3.5 o 3.8 GHz o Core i7 Kaby Lake 4.2 GHz (id ImAC18,3) / Retina 5k display. Fai riferimento alle guide del modello più vecchio dell'iMac 27" Retina 5K display (fine 2014 & 2015), dato che il sistema è molto simile.
293 Domande Visualizza tutte
Can I add in iFixit "replacement" RAM to upgrade?
I bought this model with the basic two sticks of 4GB RAM. It has been sufficient for almost all my purposes, but if I can cost-effectively upgrade, it would be helpful.
My question is just whether this RAM for sale on iFixit (PC4-19200 4 GB RAM Chip) can be added alongside the original RAM to upgrade to 12 or 16GB.
I would have assumed that it could be, except that the product description only mentions that one can “replace” RAM with the part. Has anyone successfully used this same part to expand the memory in this iMac?
Immagine PC4-19200 4 GB RAM Chip
Prodotto
$39.99
Questa è una buona domanda?
Punteggio 0
1 Commento
Simple answer, is Yes!
As long as the RAM specs are correct you can mix them.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Standard RAM:8 GBMaximum RAM:64 GB*
RAM Type:PC4-19200 DDR4*Min. RAM Speed:2400 MHz
Details:Supports 2400 MHz PC4-19200 DDR4 SDRAM SO-DIMMs (260-pin).
Details:*By default, 8 GB of RAM is installed as two 4 GB memory modules (and two slots are unoccupied). For some curious reason, Apple only permits this model to be configured at the time of purchase with 16 GB or 32 GB of RAM for an extra US$200 or US$600, respectively. However, as first determined by OWC, it can support up to 64 GB of RAM with four 16 GB memory modules.
Here’s a video on how to install it:
Third one down:
https://9to5mac.com/2017/08/01/review-en...
Punteggio 2
I see what causes the confusion. In my experience, different types of RAM may be used inside a machine. My guess is, they assume you’d use this part as a replacement, as opposed to an addition.
Generally speaking, you would want to stick to the same manufacturer and ensure that each DIMM has similar capacity. That is, however, not a rule written in stone. So, in short, I’ll say that you should be able to upgrade the RAM on your machine with the one you’ve looked at (assuming it is compatible with your particular model).
Cheers!
Punteggio 0
Aggiungi la tua risposta
davidholyokeodell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 89
