Salta al contenuto principale
La Sony Handycam DCR-HC51 (codice prodotto DCR-HC51E, nome prodotto DCR-HC51) è una videocamera con touch screen LCD (display a cristalli liquidi) e zoom ottico 40x.
How to fix error c 32.11
i tried hitting the bottom diconeecting power and shaking it
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
This error code indicates that the tape itself is not moving and the unit has shutdown to prevent any damage to the tape. There are a number of possible causes for this since it is a generic error message. There can be a loading problem, or the takeup reel is not moving or there is no movement of the tape at all. In any case, this problem will require further investigation by a service provider. Without seeing the actual camera and investigating internally, there is little that can be done in this forum.
Punteggio 1
2 Commenti:
most likely is mechanical problem you may fix it if you are mechanically inclined the mechanism may need a good cleaning and a little oil and you are on your way to your recording I love my hvr z7
Nick y
da
Be very careful with oil in a tape unit. This is the most common cause of complete failure. Any oil where is shouldn't be often results in the tape adhering to the heads and other parts. I would NOT suggest using oil at all.
da
Kassetefach geht nicht mehr , Fehler C32 - 11
Punteggio 0
Aggiungi la tua risposta
alex sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 46
Tutti i Tempi: 2,135
