Salta al contenuto principale
Lanciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
1199 Domande Visualizza tutte
Why does my iPhone X show vertical Lines?
So after a drop my micro and disolay start not working properly
so my question now: can i replace the screen with a new LCD and will it start working normally again?
best regards
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
This is your answer - this is common especially in the iPhone X. Now although there is no signs of physical damage this can be caused by excessive pressure or even a faulty screen so you need to take it to apple.
iPhone screen has lines through it
Punteggio 0
2 Commenti:
So would a screen replacement fix it?
da
yes correct. 100% screen replacement. please mark question as answered.
da
The display and front microphone are part of the same module, so assuming the connectors of the display assembly to the logic board didn’t damage in the drop, a display replacement will fix your issue most likely.
Punteggio 0
Aggiungi la tua risposta
Nenadbrateu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 5,444
