Salta al contenuto principale
A laptop by Lenovo that can function as a tablet.
45 Domande Visualizza tutte
Trouble disconnecting display connector cable from motherboard.
I am trying to replace the screen on a Lenovo Yoga 720, and one of the steps to remove the motherboard is to disconnect the display connector cable. I am pretty sure I am just supposed to pull upwards on the plastic flaps but they feel like they are going to break. Is that the correct way to disconnect this cable?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The plastic flag can be used to pull the connector, but you should use a plastic tool with a flat tip to loosen both ends of the connector, the plastic flag will help when reconnecting.
Punteggio 1
Aggiungi la tua risposta
Sarah Ybarra sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 950
