Salta al contenuto principale
La Kodak EasyShare C913 è una fotocamera digitale da 9,2 MP.
What does .AF mean?
When you push down the flash, it goes off but than it goes off AGAIN and the picture turns out as just a white blob. Why does the flash go off the second time?
Questa è una buona domanda?
Punteggio -1
2 Commenti
Laura Gross, just as a follow up, I was wondering if you got your camera working again.
da Condividi
Midway Island.
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
Not sure about the .AF. It would depend where it shows up on your camera. I do believe that it shows that your Auto Flash is on. The double flash is done by your setup. For Red-eye The flash fires twice—once, then again when the picture is taken. So you should check your manual, available here,and see how to turn it off. I hope this helps, good luck.
Punteggio 1
Aggiungi la tua risposta
Laura Gross sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 22
Tutti i Tempi: 954
